Lifting Lug Design Query
Hi everyone, I am trying to self teach some theory around the design of lifting lugs and doing a Google search doesn't throw up that much info, however I have found a report from David T Ricker which is pretty self explanatory, however I have a question which I hope someone can answer. On p152 he is talking about the 3rd failure mode being "shear whereby the pin may push out a block of steel as it attempts to plow through the edge of the pin" The formula for the approximate shear load he gives is:
Pu = 2(0.4)Fy et
My question is what is the 0.4? Hopefully someone can answer this very simply for me!!
Pu = 2(0.4)Fy et
RE: Lifting Lug Design Query
