We are compining an AHU DOL Starter & BMS Interface DDC inside the same 60 x 60 cm Enclosure
We have in our project to combine Each AHU Starter (DOL) and its BMS interface (DDC) inside one enclosure 60 cm x 60 cm., is there will be any interference between the power cable feeding the starter and the BMS DDC performance , as they will be contained inside the same enclosure, and is there will be any affect on the signals of BMS carried by the BMS Cable connecting that DDC ? And if there will be an interference what will be the solution to avoid such that, as we already assempling them now in one enclosure,
Eng. Mohamed El Sayed
Technical Office Manager
