commercial market alteration
any thoughts on determing a infiltration rate for a market 2 automatic sliding doors . one entrance , the other exit
i was looking a some data for estimating passages per occupant per hr and come ou .
its a one story building with roof hvac units.
if building pressure is positive how much can infiltration can be neglected
RE: commercial market alteration
Second, stick these phrases in Google:
infiltration guidelines hvac design
infiltration guidelines energy modeling
infiltration guidelines sliding doors
You'll find about 100 good references from ASHRAE, PNNL, NIST, MIT, NIBS, and others.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
thats my point
i'm looking for someone with experience in the area , not 5 techical papers with an unlimited buget .in this economy its hard to turn jobs down. so, we take them an try to figure them out
cut to the chase on big picture
i have ashrae volumes 1-4
Technical paper is the result of experience and studies.
for the economy side, if the infiltration load will cause a damage to business, then it is better to close this business and look for something else.
This may not really be accurate, but has some science to it. When I have time I research more on what DRWeig suggested. but the method i described should work for the load. it won't really work with energy simulation since that flow will be highest at the coldest day.
An air curtain can mitigate a lot of what will sneak in. A vestibule or revolving door even better.
In my area, the folks in the small markets just have to dress warmly and wear double socks in the winter.
Best to you,
Goober Dave
