Boil off pressure control valve
Okay, so I am looking at a cryogenic storage tank that uses boil off control to maintain pressure.
When the vapour pressure reaches the defined level the PIC open the boil off control valve, and it flows to the vapour compressor and then around a re-compression loop.
So my question is: is their any reason why the system needs the pressure control/boil off control valve. From my little understanding, it feels like the system would work the same without it...i.e the vapour pressure would build up in the pipeline to the vapour compressor, and tank room, and enter the compressor. So I am guessing there's probably a good reason why the boil off control valve is required but I cannot figure out why - does anyone have any thoughts?
RE: Boil off pressure control valve
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
