The SHELL99 element type is no longer supported.
Hello!
I have a composite fe modell (created and solved in older version) with SHELL99 elements. I want to open it, and look at the properties of the modell, but I have a newer Ansys version (14.5 and 13) and it doesnt support this kind of element. Can I expand the element library, or import element types? What could be the solution?
Thanks!
RE: The SHELL99 element type is no longer supported.
the GUI will not show undocumented element types, but solving and showing results should still work.
Alex
MESHPARTS
Tuning Your Simulation
http://www.meshparts.de
