GPU not use in proccess
hi
I run explicit and implicit solver to solve some example, I check Use GPGPU acceleration in Job setting.
But I monitor GPU (by Gpu-z and AMD system monitor), and usage of gpu was 0 %!! in some game such as Call of Duty was 60%.
how Can use GPU Process in Abaqus? any Config or software need?
system specific:
CPU: FX 8150
M.B: M5A99FX PRO R2.0
VGA: ASUS 7970
Ram: 8GB
hard: 1 TB ,western digital
Case: X5
Software:
windows 7 64bit
Abaqus 6.12 64bit
RE: GPU not use in proccess
Im not sure that Abaqus supports AMD cards. It might only have Cuda support (nvidia) and not opencl/stream. Im not sure. Nvidia cards from the Quadro line and tesla are the only ones that can be used and ive read this is due to the ammount of VGA memory (and probably drivers too). Do you have a GPGPU license?
Best regards
when I checked this option and submit, I don't see Error and warning.
