Macro to link part properties to existing title block text
I want to create a macro that will link to the parent of the front view and use the properties of that parent to modify an existing title block. Additionally I need it to run on the active sheet of multi sheet drawings. Using info from thread560-330652: Edit an existing Title Block using VBA Macro I am able to manually edit the sheet1 text using a macro, but I would prefer to pull the information from the parent. I purchased VBScripting for CATIA V5, but the sample macro there requires the name of the part document be entered in the macro code.
RE: Macro to link part properties to existing title block text
You can take a look also here and see how you can modify http://www.eng-tips.com/viewthread.cfm?qid=300505
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
