Another Mortise and Tenon,(M+T), Question
This barn I am reviewing will be constructed at a different location than its original one. When checking the mortise and tenon connections, The pegs, ( wood dowels) are not adequate to resist the uplift loads at the posts to purlins connections. Can I rely on glue to transfer the loads? If the tenon is fully engaged, its capacity in tension is adequate. The cross section of the tenons is 1-1/2" x 7". I know glue is used with M+T joints but not sure if it is used in large joints of barns/houses.
Any comments are welcome. Thanks for the help.
RE: Another Mortise and Tenon,(M+T), Question
Not according to the IBC unless it has been tested by a testing agency.
I have seen some local jurisdictions accept glued joints though, but very few.
This is a sticky area.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Thanks Mike. I wonder what would you do without using steel straps or plates. I want to keep the wood clean of any visible steel.
Do the dowels fail in shear or bearing?
Can you post a picture of the connection you are working with?
Mike McCann
MMC Engineering
Call an Amish Engineer - they do this all the time!!
Seems a little far-fetched, but I'll ask anyway: if the dowels fail, but the hole doesn't tear out, is it possible to use steel/aluminum dowels? Maybe cut short of the wood face with wood plugs at the face for cosmetic effect.
Can't install lag screws through the 8X8 beam into the 8X8 column due to the end grain connection of the column, so...
I would seriously think about either increasing the capacity of the wood dowel, either by diameter or species or both, or use a metal dowel with wood cover plates at the outside of the 8X8 beam.
Mike McCann
MMC Engineering
Can you use slightly larger dowels and use a real hard wood... I've replaced dowels with ironwood pins (hophornbeam) for added strength. On one project, I had intended the pins to protrude... contractor (master carpenter trained in Switzerland) had recently picked up a Japanese pull saw and cut the pins off flush. Can you use a steel pipe with a wood plug in the end?
Dik
If the Queen Post is not too long, you could drill a hole through the beam, post and purlin and use a threaded rod as a tension member, completely hidden from view by the 8x8 post.
If it is too long, you could laminate two 4x8 posts with a groove to receive the rod in the middle.
BA
Check out the Timber Frame Engineering Council.
Link
TFEC-1 provides guidance on mortise and tenon joints.
Larry Reynolds
LLR... excellent link...
Dik
Thanks all for your help. The link LLR provided is excellent indeed. Out of the options provided, the owner ended up accepting adding steel plates at a couple of locations.
