Vertical Valve and Actuator
First time in here. I'm an entry level structural EIT, and know little about mechanical as of yet, so bear with me :).
I have been presented with a ball valve (3 piece PetrolValves reduced bore metal to metal seal trunnion mounted) installed in the middle of a pipe in the vertical position. It is supposed to have an electro hydraulic actuator (custom...but along the lines of Rotork single acting fail close) attached to the side of the valve and sort of cantilever hanging off in space. This actuator is 520 lbs, and I am tasked with finding a way to support it since it is just hanging off the valve. I have been googling ball valves and actuators and can't find any pictures of them installed vertically...is this an issue? I have only seen them attached to the valves (in the horizontal) and other than that free standing...what is the typical way one of these would be supported in the industry? It is all on top of a steel grating platform...my coworker says at the base supports often have 2 plates sandwhiched on either side of the grating with bolts going through them.
The other thing is I don't have much room...there is a large horizontal pipe (looks like 20" pipe from the 3d model I saw) going across right under where the actuator is hanging in space (with maybe 6" clearance in between?). There are also a large mechanical box and a W column sort of catty-corner behind it a few feet behind and to the side. Do they usually install these vertically? Ideas on how to provide additional support?
RE: Vertical Valve and Actuator
Petrotrim Services
www.petrotrim.com
http://files.engineering.com/getfile.aspx?folder=0...
http://files.engineering.com/getfile.aspx?folder=e...
http://files.engineering.com/getfile.aspx?folder=d...
Thank you!!!
rmw
As can be seen in the picture above, the piping section in question is U shaped, and the upper horizonal pipe appears to be supported by 2 L Shaped wide flange frames with 2 EA u bolts going around the pipe. The vertical part itself with the valve and the actuator brances off of the 12" pipe with a 2" weldolet at the base. This may become a 3" weldolet followed by a 2" reducer if it adds any significant support. I am not too privvy to the mechanical details as I am a new entry level structural and all they threw me was this 3D PDF, but my best guess is yes, there is potential for thermal expansion. I hope I communicated all of that in a way which makes sense.
Thank you
Whatever you do, the older engineers will probably shoot down your idea and then spend more time lecturing you on what they would do that the amount of time it would have taken them to have done it in the first place.
I would say they expect something simple that is not in the way of any walkway or other necessary access, such as a valve handle. Yes, putting plates on top & bottom of floor grating, with bolts through, is done. You want to watch out for creating a tripping hazard.
Check the actuator to see if there are any obvious attachment points you can bolt to. Some people just sit them on a little saddle, if there is not much vibration.
520 lb. is not a whole lot to support with, say, a piece of 1" pipe column up underneath it. Or 1-1/2" SQ. tubing, 10 GA or 3/16" wall.
- What you show in the photos suggests you will have a real problem if you leave it as is.
- You need to rotate the valve operator 90 degrees clockwise so the operator is directly above the "host" pipe (blue horizontal line). Raise the valve if necessary.
- Next you need to support the valve operator from the "host" pipe. This will allow the support and the valve operator to move together.
- Then you need to remove the two structural steel supports. The steel will not move but the pipe will. These supports currently present a risk of ripping the small bypass line off when the bigger "Host" line expands or contracts.
- You do not need the supports for this small line but you may need a stabilizer to prevent damage due to vibration. This stabilizer needs to be tied directly back to the "Host" line so that it moves lineally with the "Host" pipe
prognosis: Lead or Lag
Pennpiper has a sound proposition under the condition that the valve and actuator forms a solid, compact unit. Another way to attach the problem is to mount actuator and valve together in best possible position (re pennpiper), then mount both locked in position as a unit on a common 'footplate'.
The 'footplate' could be anything from a plate to a framework, or a single, more simple contraption, part of a beam etc. The idea of the 'footplate' is to take all weight and forces away from the pipeline, and then support the footplate as suitable to existing framework.
Further the 'footplate' will give you a higher degree af freedom where to select and place support.
