stiff clay bearing capacity
what is the maximum design bearing capacity of stiff clay in kPa (theoretically)
RE: stiff clay bearing capacity
Mike Lambert
That is being really conservative for "stiff clay". Presumptive values are for use when there is no actual geotechnical information available. If there is enough information to classify the clay as "stiff", then the clay should be much better than 1500 PSF.
