X52 / API 5L Seamless Pipe Fitting Equivalent
I am using seamless joing of X52/API 5L piping and I am trying to determine what material grade to use for the tees and 90s.
My question is this:
1.) What material grade can I use for the fittings (90's and tee's) so that my X52/5L piping is the "weakest link" and the governing element?
I know that ususally B31.3 says that all standard fittings are rated for at least the equivilent pipe rating. I would ususally use SA234WPB, but this has a lower yield strength than X52 / API 5L.
I am dealing with sizes ranging from 4" to 12" nominal diameter (sch 80).
Thank you very much in advance!
RE: X52 / API 5L Seamless Pipe Fitting Equivalent
I am somewhat curious though as to why you're using 5L grade X52, but designing it to B31.3 as you only get 10% more stress value than grade B?? Also all the fittings tend to be much more expensive than standard A 105. It doesn't normally make sense to use pipeline materials in a piping code. You can normally design piping within a plant to pipeline codes (b 31.4, B 31.8) if you have to or if you have lots of meters of pipe, but ususally the cost of the fittings (elbows, flanges etc) to match the X range of line pipe is much higher than any marginal saving on pipe material
