Which solver would be better for this case : Implicit or Explicit ?
I am trying to simulate the inflation of an inflatable structure for one of our products. Currently I am using an explicit solver for it (explicit FEA+CFD) . The problem is the inflation time is 4 seconds. The analysis is highly non-linear with surface to surface contacts with outside bodies and also self contact. The material model is also non-linear with large deformations. It involves fluid structure interactions (employing both Eulerian and langrangian mesh). All these point towards explicit methods but given the time for inflation is 4 seconds means it takes a lot of time to solve (about 40 hrs currently) to solve for 4 seconds. Moreover the meshing is to be done keeping in mind the timestep needs to be as big as possible for a reasonable solving time.
I have been considering trying out an implicit solver (dynamic, coupled fluid structure) since it will allow me to use smaller elements without worrying about the timestep. However, I am worried if it will actually improve or increase the solving time. Cause issues with convergence due to the high degree of non-linearity. This would mean changing the solver we use as well, so license costs are another factor.
Which do you think is better suited for this problem ?
RE: Which solver would be better for this case : Implicit or Explicit ?
Most things influence your solution accuracy though.
