NX8.5.1 BLEND PROBLEM
Hi Guys,
I probably should call GTAC, but I thought maybe someone could answer this for me. We've just moved to 8.5 in the last month and we're having a problem with the Blend command. As you can see on the jpeg, the blend isn't making it all the way to the end. The little triangular area would have been included in NX8.0. I've tried changing as many settings as I can, but it's always the same. Anybody have a solution to this problem? Is there a setting I'm missing?
John
John
RE: NX8.5.1 BLEND PROBLEM
If you can't do this then we need more picture from different angles and using both NX 8.0 and NX 8.5 do that we can see what it's supposed to look like as well as a better idea of what this part of the model looks like.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Here's an 8.5.1 file of the portion in question. I hope it's enough to show the issue. I don't have 8.0 installed anymore, so I guess I can't really say with assurance that it would have worked in 8.0. We do a lot of this kind of thing without trouble, so I assumed (stop laughing everyone) that it would've been ok. I'm not trying to be one of those guys who complain at every little thing, just trying to figure out what to do.
John
Note: file is 5.5MB
www.nxjournaling.com
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
