how to mesh this part?
hi, i need help in meshing complicate geometry part ( spongy part of bone ) , i don't know how to deal with errors occurred while meshing. thank a lot for any help . Dominik
https://www.dropbox.com/s/spoxsoo453zp2ct/bone.sat
RE: how to mesh this part?
Try using virtual geometry tools that basically smooth out the bad geometry. It won't be quite the same shape though.
i tried to use virtual geometry , but i don't know which part of the geometry causes problems. how to find out it ?
Reading in the .sat file, abaqus indicates which part is bad geometry by showing it in red. I think it refers to it as imprecise geometry, I'm not sure. If you try and mesh the part it will also indicate wich parts it cannot mesh. Take a screen grab as a record.
