Inlet Behind Retaining Wall
Any thoughts on the best wall to have an inlet behind a concrete retaining wall? We are planning on having a valley gutter behind the wall and probably the best way to drain it is to put an inlet behind the wall and pipe it under the wall to a roadway curb inlet.
RE: Inlet Behind Retaining Wall
I've put pipes below walls before. Coordinate with the wall designer on the footings. Sometimes we'll sleeve it, sometimes we'll do DIP. Check with your municipality, they may not like it, or they may have a particular way they want it done.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
