Flow element in Vertical ?
Does this mean that flow element shown in attached snap we need to place in vertical?
Because one vent is shown and drain is shown on both side of rised portion.
RE: Flow element in Vertical ?
Good luck,
Latexman
Refer to the Instrument Datasheet and Manufacturer's Installation Manual for the flow element for orientation guidance.
Good luck,
Latexman
I am more intrigued by the time taken to draw in the butterfly valve, only to car seal it open. I presume that the intent used to be to throttle the flow before the meter became a part of the system.
The drawing also states "CWS", which one would think is cooling water. There is no need to have a flow meter in the vertical direction for cooling water.
Some flow meters will not work in the vertical.
Why don't you ask the person who is responsible for the drawing?
that can change depending on the HEX layout and the HEX supplier nozzle locations,...
Good luck,
Latexman
That said, I suspect the intent is to imply the meter is in a vertical run because why take the trouble to draw that bent in, it would have been quicker to just put everything on a horizontal line and it would have been just as correct.
If I was building this and this was my only 'document' which it should not be, I'd be submitting an RFI (request for information) back to whoever did the design.
