GEOMETRY Question
GEOMETRY Question
Hi all
Im really struggling In ABAQUS regarding geometry
,and I hope I will find the solution with your help, actually I sleeve in a hollo-bolt which is cylinder in the upper part and flare in lower part, and I create the upper part using revolution and the lower part using revolution with rotation command latter, but the problem arise when I rotate the lower part, thus create a gap between them .So after merging them the gap still exist
1 . how can I tackle this problem in geometry
http://imageshack.us/a/img267/6061/geometryproblem...
2.after merging the two shapes I can’t mesh them , and I receive a message to mesh the part manually,
http://imageshack.us/a/img802/330/meshmessage.png
Please do your best in helping me
RE: GEOMETRY Question
I was thinking about this, to use revolution for both the upper and lower part, but the curvature for upper and lower part will be differnt
And this will create a problem
Please guide me through this
I really need your help
its clear that the curvature of the upper part and lower part is different because i used revolution
see link
http://imageshack.us/photo/my-images/40/ppppppppp....
Please guide me
