Small vacuum pumps
Small vacuum pumps
Am designing a vacuum box for adhesive curing. Need to draw down to approx 15" hg. I saw a GSE vacuum pump. Does anyone have any knowledge of these pumps?
RE: Small vacuum pumps
Some of their equipment looks like it might only be a vacuum blower and not an actual vacuum pump.
Also 15" hg is not a very deep vacuum at all, are you sure this final pressure is sufficient for your application?
Two big vacuum manufacturers I have come across are Busch & Edwards.
I recommend researching their oil flooded rotary vane pump range.
They will probably be more expensive then GSE however.
No experience with GSE.
Ted
I have no experience with GSE.
B.E.
