Does anybody have LC2415 with carriage start button?
The one we have did not come with one but it has the place for it. I would like to put one there, but Amada doesn't seem to want to help.
Thanks in advance
Thanks in advance
RE: Does anybody have LC2415 with carriage start button?
The long and short of it is, look through the Granger catalog and find a momentary contact button that looks pretty. Cut a hole where u want the button. Pull out the electrical schematic and find the appropriate wire numbers. Open up the little cover plate where all those other buttons are already and look for the wire numbers you found in the schematic. They should be labeled and just crimped or taped off.
I suppose if you need help finding the wire numbers make another post and I will try to find them for you.
