Inertia moment results do not update when I change dimensions and run the model in ANSYS
I have a model in ANSYS, and I want to write the inertia moment xy in relation to the origin. When I run the model, the output file is filled. However, If I change any dimensions in the model and run it again on ANSYS, the results shown don´t update, i.e., it shows always the same results. Also, when I try to run the code, I obtain the following warning:
*** WARNING *** CP = 18.221 TIME= 15:57:31
Coefficient ratio exceeds 1.0e8 - Check results.
Can anyone help?
I´m issuing *get,*vfill,*vwrite and /output commands
regards,
HMAS
Can anyone help?
regards,
HMAS
