freeze in viewport
freeze in viewport
Hello everyone,
Real quick question, is a way to freeze a layer only in a particular viewport w/o going into layer manager?
Juice
Juice
RE: freeze in viewport
For viewports created in paperspace the command VPLAYER can freeze layers in viewports.
You can also use the layer settings list in Properties Toolbar.
Farzad
If you have the express tools, you can use the layfrz command within the viewport. This will freeze the layer in the viewport and not globally.
Brian
