Shaft current transformer for hidrogenerator
To protect hydrogenerators bearing it is used shaft current transformer installed around it and a relay attached to the transformer.
I looked at various companies but I did not receive any answer. My question is if you can provide me the names of companies that produce these transformers and the relays which is connected to this current transformer.
Thank you.
Thank you.
RE: Shaft current transformer for hidrogenerator
The original patents for the shaft current transformer and associated relay belonged to ASEA of Sweden. Very likely this system is still available from ABB. Do a search of the ABB library and you may find what is currently offered. Or google shaft current protection.
rasevskii
http://www.abb.us/product/db0003db004281/c12573e70...
http://www05.abb.com/global/scot/scot296.nsf/verit...
http://www05.abb.com/global/scot/scot354.nsf/verit...
http://www.rmspl.com.au/handbook/2c139.pdf
Walt
I got an answer, but the ABB say they no longer manufacture the relay abb Raric, although on their website is this relay. In the Raric prospectus is listed also the transformer relay. So far I have not received any response. Is it not important that relay?
