Heat exchanger retubing with thicker tube
Hi everyone.
We are going to retube a Heat exchanger with a thicker tube (2,7 mm - BWG 14) than original (2,11 mm - BWG 12).
The difference in weight is something around 1 ton.
The exchanger weighs 11 ton, and is gonna weigh 12 ton.
The exchanger is a floating head bundle.
My question, apart from the exchange efficiency, that we checked and is ok, what do we need to consider speaking of mechanical integrity
RE: Heat exchanger retubing with thicker tube
Will the new tubes be rolled/and/or welded into the existing tubesheet ?
Does the contractor have experience with the new rolling proceedure ?
Will there be samples made up for a pull-out test on some sample tubes ??
If the existing heat exchanger is a TEMA BEM and does not have a shell expansion joint, will there be a re-evaluation of the new, larger axial forces developed within the unit ?
Have the thermal condition also changed so as to make the axial thermal issue an even greater one ?
Its gonna be rolled.
Yes, he had performed several rolled procedures for us.
Yes, we will.
It does have a expansion joint!
No, it wont change.
Thanks for the help!
I'm going to guess, and it is only a guess, that if tubeside pressure drop is OK, nobody will notice any difference.
Mike
