Pillow block mounted on linear bearing???
Anyone have any experience in this? My design is a lift using a lever so when the lever is rotated providing the lift the radius changes. I thought a pillow block mounted directly to a linear rail would do the job. Any thoughts?
RE: Pillow block mounted on linear bearing???
-handleman, CSWP (The new, easy test)
