a file doesn¦t open
a file doesn¦t open
a file doesn¦t open
I am trying to open a solidworks part sent by my collegue and solidworks doesn´t want to open this file as : "can´t open. future version".
Does anyone know how to open the file?
Just precising that we are using the same version of solidworks.
Thanks for any help
RE: a file doesn¦t open
Check to make sure they are the same SW versions.
Otherwise, try parasolids.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Do you both have the same SP installed?
quest4k
SP doesn't matter, only major releases matter, but in SW 2012SP5 and SW 2013 that should work.
Try resetting your registry FAQ559-507: Alternative to try before reinstalling and see if that fixes the issue... if it does then its a settings issue.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
