petroleum resource book(s)
I am a mechanical engineering expanding my horizons and helping our oil/gas division. I was wondering if there is resource book(s) which will help guide me with pipe data/specs, valve specs, pump selection, fluid properties etc. In mechanical engineering I regularly utilize NAVCO Piping Datalog and Cameron Hydraulic. I am still learning the differences between my current role and my new one. I am not sure if these resource books apply, if not what are some good resource books? I have access to the API resources. Thank you in advance.
RE: petroleum resource book(s)
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
