Element Force and NODE acceleration during a simulation
Hello Everybody,
In order to implement a controller within the ANSYS programm, I need to have access to the acceleration of a node and the force acting on an element. I know how to do this in the postprocess, but I couldn't find any helpful command to do it during a simulation (within a DO-loop)
What I found so far:
*GET,x1,NODE,10113,U,Y => results in the displacement in Y direction of node 10113
*GET,F,NODE,10113,F,FY => results in the force acting in Y direction on node 10113
the DERIV command doesn't work here. Also I think doing the derivation manually is not a really nice solution.. but a backup idea. I hope someone has a better approach.
Does someone have an idea how to solve this problem? The *GET command doesn't future the force together with 'ELEM' and I also couldn't find a A instead of a U to get the acceleration.
Thank you for your help.
Raphael
RE: Element Force and NODE acceleration during a simulation
Thank you for the hint. I will check that.
What I found so far is, that
*GET,acc,NODE,10113,A,Y is a way to get the acceleration if the following setting is made:
OUTRES,ALL,ALL
10113 is the node of interest. Value is then stored in 'acc'
And the force of a contact element can be read out with the following command:
*GET,Fcontact,ELEM,11013,NMISC,44 where 11013 is the element number of the contact element. Value is then stored in 'Fcontact'.
Raphael
