Abaqus Fluid Inflation Problem
Hi All,
I have successfully modeled a 3D enclosed fluid cavity, and using the FLUID INFLATION method, I have been able to inflate the cavity.
The only problem I am having is controlling the pressure gradient of the fluid elements within the cavity.
I want to add an increased pressure gradient but I am not sure on how to accomplish this.
I am unable to use the FLUID FLUX method as my cavity does not have hydro-static elements but instead has the same elements as the airbag model within the abaqus tutorial files.
Any help and advice would be much appreciated.
Thanks.
RE: Abaqus Fluid Inflation Problem
You can control pressure value inside fluid cavity in direct way through reference node of the cavity and 8 DOF (it is pressure).
If you want to increase pressure from 0.0 to 1.0 and then keep it constant just use *BOUNDARY and *AMPLITUDE keyword.
CODE
** MODEL DATA
** fluid cavity definition
*NODE, NSET=cavity-REF-NODE
 100, 0.0, 0.0, 0.0
*FLUID CAVITY, NAME=cavity, REF NODE=cavity-REF-NODE,
** HISTORY DATA
*AMPLITUDE, NAME=pressure-AMP
** time, pressure
    0.0,      0.0
   10.0,      1.0
  100.0,      1.0
*BOUNDARY, NAME=pressure-AMP
cavity-REF-NODE, 8, 8, 1.0
Bartosz
