Not sure how to get these two parts to fit together.
I want to make a T-bar handle but I an not sure I can achieve this. Can anyone help?
Please see pictures.
Thanks Daniel.
Thanks Daniel.
RE: Not sure how to get these two parts to fit together.
how can you make a T bar with 2 cylinders ?
Thanks Daniel.
- define a tangent constraint between the two cylinders
- define a parallel constraint between the front planes of the models you can find the planes in the tree at left
- define a distant constrain between the top surface of the cylindre and the left plane of the other model
if you don't find a solution tell me i will sent you an attachment
Jeff Mirisola
My Blog
Many thanks for your interest all the same.
Thanks Daniel.
Jeff Mirisola
My Blog
Cheers Daniel.
