Imports required for Excel Automation in VB.NET
Hi
Does anybody know what Imports **** is necessary in nx journal,
so it will be possible to use Range (excel).
I need to dim variable Cell.
to be used in a little sequence ...
But I got an error in line 40 - type ´range´ is not defined
line 40: Dim Cell as Range
For Each Cell In ws.UsedRange.Cells
If Cell.Value = "" Then Cell = Num
MsgBox ("Checking cell " & Cell & " for value.")
Next
lklo
RE: Imports required for Excel Automation in VB.NET
Hi, if you haven't, please try adding the -Microsoft Excel (office version) Object Library- reference, and then:
Imports Excel = Microsoft.Office.Interop.Excel
Dim Cell As Excel.Range
