Water Cooled Disk Brakes for Big Rigs
It's an obvious idea. Coming down off the Ridge Route (AKA The Grapevine) portion of I-5, on the north end's over 3000 foot descent I've seen trucks with brakes smoking or actually on fire. I've asked myself why don't they use disk brakes? Also, if you've seen European truck tractor races, you've seen the steam from the water cooling of the brakes. As an emergency expedient, water would save a truck in trouble. Why not?
RE: Water Cooled Disk Brakes for Big Rigs
Actually, there are two questions there -
1) aux cooling for existing brakes, possibly by total loss water spray, and
2) what about disk brakes, which are easier to cool?
Seems like you could do a total loss spray on the outside of the drums, and cool them pretty effectively. And/or you could add some forced ventilation to the existing drums (electric blower, thermally activated?)
I wonder if that (either of them, actually) could be a saleable aftermarket item?
Jay Maechtlen
http://www.laserpubs.com/techcomm
http://www.thetruckersreport.com/truckingindustryf...
TTFN
The bottom line is always the bottom line, and almost no one wants to pay THAT price, and they're willing to gamble. We developed a safety system for preventing a large portion of helicopter aerial collisions, and even with a relatively low cost, there was great reluctance, because outfitting the entire fleet would have cost ~$250 million, and that buys a lot of bullets and prevents losing bullet carrying capability.
TTFN
http://www.foundationbrakes.com/media/documents/ai...
No matter how much performance you build in it does not increase safety if the operator just uses the extra performance and leaves the same estimated margin. It saves time, but does not increase safety.
A total loss water system would require a lot of water at the cost of payload which means many operators would not use it when needed most.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Here's one with the steam going downhill:
Here's the water spout:
Here's the 400 gallons water tank:
for more info: Link
The idea of a water spray would not be for general use, but a desperation measure to slow a truck when it has lost brakes. Presumably, merely cooling the brakes enough restores function sufficient to slow the truck to a safe speed or stop it, and if the truck then descends within the recommended speed there is no problem. How much water would be required is a question, but I bet it's not a lot for a one time event IF the driver uses it as soon as he realizes the brakes are in trouble (assuming the brakes are just above operational temp). That's where sensors come in. The supply could be replenished at the next stop.
TTFN
http://fleetowner.com/regulations/truck-stops-here...
JackAction, thanks for the photos. Logging trucks are special equipment on especially steep roads and I can see that they would be more likely to need extreme measures. For I-5 the argument would be is there enough of a need, but at least I see that it is being done on some trucks.
I expect that pad life is related to pad area - and lots of other factors, probably.
But I don't remember front drum brakes going as far as disks go now- I usually get 50-70k miles from front pads.
What did classic drums get? 20-40k miles?
Disk brakes can dissipate more heat than drums, but generally need some speed to pump air through them.
I took our Aerostar up a steep dirt road once - that was fine.
Coming back down, low gear wasn't low enough to control speed, the road was too steep and safe speed was maybe 15MPH.
The brakes faded badly, I barely got it stopped.
The disks weren't getting any airflow at 5-15mph, and overheated.
That's why I mentioned forced ventilation!
Jay Maechtlen
I agree the vents in the rotors rely on wheel speed to pump air so high speed light weight suits them better than low speed heavy weight.
Pat
for site rules
Regarding maintenance costs, I have always found disk brakes much easier to work on than drums. Some designs like my motorcycle, the pads can be removed and changed by pulling one pin out, no need to remove the wheel. I've never seen a drum that can be serviced like that. Time is money in trucking so this could potentially save money.
However, engine braking contributes. It could be all you need depending on grade, speed and gear.
Are you referring to "jake braking"? Is that is the most effective of several techniques? The speed limit for trucks on the grade is 35mph and at that speed, jake braking could probably hold the truck. But, I've seen trucks doing more than that.
http://www.crashforensics.com/tejonpass.cfm
That's not the case for I-5, though, since its grading was designed for even older trucks. And that's the reason why there's a brake check area prior to the downgrade. Invariably, the reason trucks have absymally poor maintenance, which is why changing the braking mechanism will most likely not help; the truckers will defer maintenance to the point of failure.
TTFN
TTFN
Cooling - treating the disk vanes as a fan - is proportional to speed, more or less.
So if the cooling is sized correctly for high speed, high energy stops then you should be ahead of the game at slow speeds.
At any rate, considering that there is a substantial population of trucks with the tractor's front brakes disconnected because drivers still think that they get better braking performance that way I don't think there is much of a market for disks.
If the driver lets the speed build up too much there is nothing but the escape road that is going to save him.
In my experience with truck brakes years ago (haven't messed with them since I was on a SAE Brake Div, retarder sub-committee about 20 years ago, so my info may be old) was that disc brakes would save the rig, but destroy themselves. In other words, in an abusive braking situation, you could get safey down the hill, but the discs would be completely gone, requiring replacement at the bottom. At least the driver would be alive to perform the replacement, but it would mess up his schedule.
Drum brakes, on the other hand just get hot and expand away from the ability of the pads to maintain contact with them, thereby releasing the rig to crash after a very fast ride, but after the crash, when the drums cooled off, the brakes on the (now) wrecked vehicle would work just fine.
Any driver who is smoking his brakes on the Grapevine is (A) smoking something himself, or (B) from back east somewhere. I did get a motor home's brakes a little too hot on the Grapevine once and was in for a ride I'll never forget. The worst part was that my family was on board.
There are all kinds of retarders on the market to help with productivity on downhill runs ranging from engine brakes already mentined (although I believe someone has been reading too much sales literature based on testing we did during my stint on the committee) but all of them add some weight, and weight is king in OTR trucking. The lightest of course is the engine brake.
I once demonstrated an electromagnetic retarder on an 18 wheeler (trailer axle mounted) that was 4 times more powerful than the engine brakes of the time and when the operator applied the first step of the four step retarder actuator and snidely turned and sneered at me 'see it is about the same as the engine brake' to which I replied, "yes, but you have 3 more positions, all the while grabbing the retarder control handle and moving it through the second, third to the fourth position. If only I'd had a camera to capture the look on his face as he commenced to grabbing gears to match his rapidly declining speed.
rmw
Some truckers do push the margin. You see some outpacing others by 10 or 15mph. However, how fast they can safely go depends on their load. Although I've never seen a runaway truck, I always can smell their brakes on the Grapevine grade and usually there is at least one with brakes smoking by the time they reach the bottom.
I wouldn't assume a trucker in trouble must necessarily be on something or dumb. All that has to happen is he gets a wrong weight for his load or he makes an insufficient compensation for it or he underestimates the grade. Your own experience with your RV shows it's easy to make a mistake.
The water idea was for a one-time emergency use, not continuous. How much do you think would be needed to save overheated brakes and slow the rig to a safe speed or stop it? How about for a motor home?
In Malibu there is a truck killing road called Kanan-Dume (Doom) Road. Coming out of the Santa Monica Mountains down to PCH is a long downgrade that I think truckers tend to underestimate. They are banned from being on the road in the first place, but they sometimes take it anyway. Every few years there is another, usually fatal, incident.
"The water idea was for a one-time emergency use, not continuous." but the water has to be carried continuously.
TTFN
Pat
for site rules
You've probably heard of/seen the retarders but haven't realized it-- they are commonly used as the retarder on eddy current chassis dynos. Frenelsa and Telma are the two brands that come to mind, though there are others.
Disk brakes alone, if universal, would allow a higher safe speed. Truckers should welcome that. But, adopting higher speeds on grades would use up the safety margin that disks provide as pointed out before. In any case it appears disks will eventually become the standard here as they are in Europe.
The CHP says the escape ramps get used 30-35 times a year. Truck traffic is up to 22,000 per day. I think most truckers in trouble simply ride it out. They can probably negotiate the car traffic up to about 70-75mph. I've seen only a few flipped over trucks off the shoulder at the bottom of the grade and those were not necessarily runaways.
crersu75, I looked up he retarders, thanks.
Now things happen, like missing a gear on a downhill where one would have to use more brakes than normal to bring the rig back under control. But the average driver who is smoking those brakes you are seeing is just a dunce and needs to be doing something else. Sorry - it is a hard saying, but look at the 99% of drivers that arean't smoking brakes on the same hill.
The exception I mentioned earlier is where the smoke isn't the brakes, but grease from a leaking wheel seal burning off when the brakes get hot. The brakes overall may be hot, but not too hot to control the vehicle, but hot enough to torch off any greast built up by grease leaking through a seal onto a brake drum.
Now Crerus, Frenelsa & Telma.... That takes me back several lifetimes. 140 AP, google Klam, Zelu, and the word "ralentizadores" if you want to read any more about electromagnetics.
rmw
I certainly agree that it is the driver's professional obligation to not overrun his brakes, but mistakes happen to the best and IIRC much more than 1% of the trucks on the grade had smoking brakes and I could always smell somebody's brakes. However, most of my experience was in the '90s when I did about 120 trips to the Bay Area. I take that route only a few times a year nowadays and only to the Frazier Pk turnoff. The difference in that is that I'm not in a lane to watch the fastest trucks nor do I go all the way down.
Now it occurs to me that in my memory most smoking brakes I've seen were on the trailers, not the tractor and I think that makes a difference. Anyway, I did run across a quote by a trucker who also noted he always sees someones brakes smoking. Like I said, some guys run 10-15mph faster than the other trucks and that may or may not be ok.
That means that 99,999595 % of the trucks don't have any problems going down that hill. At least nothing too serious. Furthermore, those escape ramps did the job: stop the (very few) runaway trucks. And if we're talking about modifying the brake system of all trucks & trailers across North America, even the ones that don't go on these kinds of roads, the number of decimals needed for this number will become ridiculously high.
In my honest opinion, that should answer the question in your original post:
Otherwise, if we really want to eliminate all possible accidents due to deficient brakes, we could also ask: Why not put a parachute in the back of every trailer in case of emergency, just like the ones used by dragster?
Even then, I'm sure there will still be a parachute that won't open at one time or another when needed.
Guess whose brakes get abused with that combination. There is even a term for it (or at least was 25 years ago when that scene was part of my world) amoung owner operators: "Company jake brake" which meant that they would reach over and pull the trailer brake handle to ensure that they do the lions share of the braking while sparing the use of their own tractor's brakes.
Secondly, company trailers get bounced around and often spend large periods of time out and about before they make it into a terminal where maintenance is performed on them, so encountering a company trailer with brakes in all states of disrepair isn't uncommon at all which means that when they are used, some brakes on the trailer are doing all the work while others less well adjusted are less heavily loaded. That is even true of company trailers behind company tractors.
So, not suprising at all to read that you see more trailer brakes smoking.
rmw
Thre is no need for innovation. There is a laundry list of equipment that will aid trucks get downhill or even do all the hold back required. The unfortunate thing as Pat P states above is that truckers are not willing to sacrifice payload - or that is to say that - anything that they perceive would reduce payload (because some of what they do replaces payload but they accept it as normal and I'll name a couple below.)
For now the comment is about the need to innovate or not. The retardation system that will do all the holdback adds about 1500 lbs to the rig's tare weight and the industry won't have it. For the weight of the water that you proposed adding, they can have the finest retarders on the market. Heavier retarders are fairly well accepted in the offroad community where they don't have to worry about state or federal weight laws.
I know first hand of a situation where a trailer axle retarder user was smoothing off of I-8 eastbound out of San Diego on a serious downgrade - 8% which is maximum allowed on the Interstate system - at night at about the automobile speed limit of 70 mph (and knowing him, I bet he was crowding that by a few mph) and due to a total malfunction of the electrical system associated with his 12/24V starting system, when a certain circuit breaker opened up, he lost every bit of his electrical system, lights, engine controls, everything including his electric retarder. Well, the saying is that cold brakes will stop anything and he proved it that night. He stated that he wouldn't have been able to stop like that twice in a row, but he did get it stopped and to the side of the road whereupon the circuit breaker cooled off, remade and his electrics returned. I know about it because he came straight to me and made me figure it out and come up with a fix, which I did. I don't remember all the details now of what we modified, but if I studied a 12/24V starting system for a few minutes I'd remember.
He had a 1693 Cat engine which was adapted from a motor grader engine and there were no engine brakes for that model. He typically ran downhills so fast with that trailer axle retarder that he had to put a sign on the back of his trailer warning other truckers not to attempt to follow him off down grades. The trailer axle manufacturer showed a photo of his trailer rear doors at major truck shows and truckers stopped by with regularity and told stories of trying to follow him and getting into big trouble. His CB handle was 'Sarge' and the stories about that old man were rampant in those days.
He was different in that he was willing to make the payload sacrifice and understood that the increase in productivity (he ran a reefer between Texas and California, chickens westbound, produce eastbound for a grocery chain) plus the peace of mind made up the difference.
And now for the perceptions.
The American trucking industry, and I include Canada and most of Central and South America is in love with the twin screw tractor while Europe figured out decades ago that they couldn't afford all that extra dead weight for no more benefit that it produces. So there is 1500 lb. right there.
Trailers knows as "taughtliners" or "curtain sides" add about 1100 lbs to the weight of a trailer but those who think that faster unloading from the sides is worth that weight penalty gladly pay the price for payload reduction.
Electric starters - I knew of a bulk hauler and tanker outfit in Utah some years back that did the math and realized that air starters (and associated equipment) were lighter than electric starters and associated equipment so their fleet was equipped with air starters. It was interesting one bitter cold winter day I was at their shop to see one of their rigs out against the fence with an electrical cord and an air line strung out to the rig to try to get it started (electricity because the battery was dead and the engine kill switch was electric and needed power to allow the rig to start).
So it is all a matter of perception. They accept what they perceive they need regardless of the weight it adds and reject what they perceive that adds weight if their granddaddy didn't do it that way.
Where the electromagnetics really became popular was in France and Spain in the '60's - '70's when the national governments gave an automatic overweight allowance for the weight of any retarder on board. Why not go for the best which was also the heaviest. I am not so sure those laws still apply since I have been away from it so long.
I don't know where all the work we did on the Retarder Sub Committee for the SAE is today, but there is quite a bit published on the topic if you can find it, but the bottom line conclusion was that until and unless governments got on board and gave an overweight allowance for safety equipment it wasn't going to happen. IN the case of our country as you know, that involves getting 50 states to all get together on something. Hearding cats would be easier.
And then of course, there is the old fashioned way that was done before Clessie Cummins invented what Jacobs Chuck Co would market as the "Jake Brake" and that is to select a gear low enough to ride all the way down the hill without any or precious little use of brakes and just go slow. The Grapevine is a long way to gear low and go slow especially when the "large cars" are streaking by you in the fast lane, but many a trucker has done just that so that he would live to see another day.
I have personally driven many a load of skiiers in large motor coaches down some of the nastiest slopes Colorado has to offer with nothing but gears, but when there are up to 46 people sitting behind you whose lives at stake you find out that it can be done. We didn't go fast, but noone objected and we all lived for me to be able to write this.
rmw
When you find a variety of solutions to a problem it's a sign that probably none of them work well enough or have merits that obviously outweigh their drawbacks. I think THE solution to heavy truck braking on grades has either not been found -or exists but has not been mandated.
Note that friction brakes alone could do the job under all conditions of speed and grade given ENOUGH dissipation. The rate of energy dissipation to hold a constant speed on a grade is only double at 70mph what it is at 35mph. That energy is basically just the gravitational potential energy difference between two altitudes. This energy does not disappear. It has to be dissipated. The rate of dissipation required is proportional to the rate of vertical descent. All the various techniques transfer this energy to the air. Jake-braking pumps air to high temperatures and pressures and releases it without getting any return energy in the expansion. Electromagnetic brakes have a lot of airflow and fins to pump energy to the atmosphere identically to friction brakes. These techniques add dissipation to what the friction brakes provide -no "better" than an additional or better set of friction brakes could do.
Here "better" has to do with space, weight, cost, etc.
For example, at the Telma website they have a video with Jay Leno that shows their $10,000 driveline unit. Coincidentally, its heatsinks look like large brake disks. These heatsinks limit how much braking this unit can provide because, unless the unit can charge a battery pack, the energy from braking has to go to the atmosphere through these heatsinks. Now these heatsinks could be replaced by two cheap same-sized disk brakes and dissipate the same or probably much more energy (because they can operate at a much higher temperature). So, additional and better friction braking is a possible solution that exists but has not been mandated. Of course it may not be the BEST solution and maybe should not be mandated.
rmw
For 'generic' rigs that find themselves in the occasional unusual situation a more cost effective solution than making special equipment standard could be to provide appropriately spec'd shunt tractors at the top of the pass to take the load to the bottom
- However the few sites that I looked at allegedly referencing the infamous internal Ford $$/life memo refer to roll over accidents
http://www.calbaptist.edu/dskubik/pinto.htm
This tends to be supported as some sites maintain stuff like this -
" 1. ...... The memo apparently wasn't used or consulted in Ford's internal decision making. It was attached to a letter written to the National Highway Transportation Safety Bureau (NHTSA) concerning a proposed regulation. Plaintiffs tried to use the memo in support of punitive damages, but the trial judge ruled it inadmissible for that purpose (p. 1021).
2. The horrifically low figure of $200,000 per life was not Ford's value; it was a value used, with qualifications, within NHTSA at the time."
http://newmarksdoor.typepad.com/mainblog/2005/07/t...
- The recall repairs/upgrades were gas tank mount protection related.
http://www.fordpinto.com/index.php?page=149
The basic gas tank location (under the floor, behind the rear axle) was and is indeed pretty common.
Volvo 240, with some plumbing added by an enthusiast.
I think we are used to the world we live in. But, we continue to seek improvement. An old movie "They Drive by Night" gives a depiction of the Ridge Route in the old days. We are light years ahead now. But for me the continued need for runaway truck ramps says we are "not there yet".
