continuous top bar in one way slabs
who designs one way slabs with continuous top bar instead of at support only?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: continuous top bar in one way slabs
BA
i mean additional continuous top bar in addition to top bars at support.
I saw specification with this. Maybe for added stability? How common is this?
anchor bolt design per ACI 318-11 crane beam design
http://www.civilbay.com
But they are misleading as this reinforcement is normally not in compression in thin slabs so its effect if often insignificant if the proper calculations are done. Tests on thin slabs confirm this. For deeper members such as beams, as long as they are heavily reinforced in tension, the logic is correct, biut not for thin slabs.
