road load total, compressors reciprocating
hello, I would like to know how ARIEL is carried out and takes into account to estimate the road load total en the cylinders of simple and double action...??
I´ll appreciate your help !!
RE: road load total, compressors reciprocating
I bet you meant "Rod Load", but I don't know what you mean by Are you asking how Ariel Performance works? Are you asking how to calculate rod load?
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
yes, my question is about, how to calculate rod load total?
Ariel program, if i remember, has the explanation included in the "Help" menu.
good luck!
-pmover
thanks you for the information, and yes, in the "help" menu includes the explanation about rod load for compression and tension, my question is about Rod load "TOTAL", they say that it is a sum between compression and tension ,but not algebraic, then how is this sum?
www.ge-mcs.com/download/orbit-archives/1q08_recipt...
docs.lib.purdue.edu/cgi/viewcontent.cgi?article=1248&context...
searching "recip compressor rod load" via google returned several articles.
hopefully someone will respond to your posting in the translation forum.
good luck!
-pmover
thank you very much for your help,the documents served me well, thank you
Link
Ariel calculates internal gas load in both tension and compression, which is a part of the API-618 defined MACCRL rod load. Their total rod load really has no meaning.
