wheel load on slab on grade
I have calculated the stress in a pavers on grade due to wheel load, using equations derived from Westergaard, but would now like to check it. Does anyone know of any software that will do this? PCA used to have the AIRPORT programme but no longer do.
RE: wheel load on slab on grade
Check PCA Slab Thickness Design for Industrial Concrete Floors on Grade with charts to work out stress OR
Check ACI 360R-06 Design of Slabs on Ground
anchor bolt design per ACI 318-11 crane beam design
http://www.civilbay.com
Corps of Engineers also has a free manual on the subject.
Army Engineering TM 5-809-12 Concrete Floor Slabs on Grade Subjected to Heavy Loads
Ajk1...you mentioned pavers...Concrete paver assoc has software for this
Thanks all for the advice. Paricular thanks to Ron about Concrete Paver Association software. I will follow up. Thanks again.
Hi Ron - I cannot seem to find the Concrete Pavers Association - would you have a link to this site?
