Problem: Output speed decreases as I loop through a HUGE assembly
My Catvba works fine when it outputs data about a HUGE catia assembly. It's just that the speed slows down incrementaly as the output file lines increase beyond around 800 to 1000 lines. My output file is Excel-- the output operation occurs for each loop in a given sub assembly. Does anyone know how to prevent the output speed from decreasing?
RE: Problem: Output speed decreases as I loop through a HUGE assembly
Try to use txt files as output instead of Excel files.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
