Pipeline Wall Thickness Change?
I'm working on a pipeline project, a 6"-300# crude oil line, along the proposed routing we have to cross a dry streambed (normally dry 10 months a yr.), the engineers have desided to directionally bore under this streambed and install a 24" dia. casing (large for future applications). One of the engineers on the project is indicating we need to "bump up" the pipe wall thickness fron Sch.40 to Sch.80 ...and is sigthing it as some code requirement. I could maybe understand this but this pipeline is 10 ft. below grade (bottom of streambed) and in a 24" STD. WT. casing. I've been looking at DOT tite 49 sect.195 (I don't have B31.4) to try to find something about this, but no luck so far. Has anyone ever run across this requirement?
RE: Pipeline Wall Thickness Change?
Also, if you plan on complying with B31.4, you need a copy of that specification.
The design requirements of this code are adequate for public safety under conditions usually encountered in piping systems withing the scope of this code, including lines within villages, towns, cities, and industrial areas. However, the design engineer shal provide reasonable protection to prevent damage to the pipeline from unusual external conditions which may be encountered in river crossings, inland costal water areas, bridges, areas of heavy traffic, long self-supported spans, unstable ground, vibration, weight of special attachments, or forces resulting from abnormal thermal conditions. Some protective measures which the design engineer may provide are encasing with steel pipe of larger diameter, adding concrete protective coating, increasing the wall thickness, lowering the line to a greater depth, or indicating the presence of the line with additional markers.
The general idea is if you can never access this pipe again, to add wall thickness for corrosion allowance, etc. so you don't have to, or lower the risk from time dependent threats. I won't argue whether I think this practice is good or bad.
What I don't understand is why put the pipe in casing if it is an HDD??? You have suffieicnet burial depth where you are under the stream, so won't get scour, wash out, etc. The casing is just going to increase corrosion risk.
ASME B31.4 403.1:
The design requirements of this Code are adequate for public safety under conditions usually encountered in piping systems within the scope of this Code, including lines within villages, towns, cities, and industrial areas. However, the design shall provide reasonable protection to prevent damage to the pipeline from unusual external conditions which may be encountered in river crossings, offshore and inland coastal water areas, bridges, areas of heavy traffic, long self-supported spans, unstable ground, vibration, weight of special attachments, or forces resulting from abnormal thermal conditions. Some of the protective measures which the design may provide are encasing with steel pipe of larger diameter, adding concrete protective coating, adding a concrete cap, increasing the wall thickness, lowering the line to a greater depth, or indicating the presence of the line with additional markers.
You need a copy of specification B31.4.
You do not have to increse the wall thickness. The pressure wall thickness design factor of 0.72 is the only requirement for all segments of a liquid line, in all areas, remote country, towns, cities, farmland or under a river, unless your Corps of Engineer's permit says otherwise (for a navigable stream crossing). It is a minimum requirement, so there may be some reason to use wall thickness, such as high axial stress from high temperature operation or something, but there doesn't seem to be a reason to do so, given the info you have provided so far. Especially since it is well below the stream bottom in an HDD bore.
Independent events are seldomly independent.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
good luck and have fun!
-pmover
A gas line might require a thicker wall, as design factors might vary if it was considered a fabricated segment.
