Part List (BOM) adding atribute parentheses
Hello Eng-Tips
I have to quiestion regarding the Part List or BOM, I just added a new column wich shows an attribute from a component and as a result the value is between parentheses, is there a way to get rid of them? (see attached image under column NOM).
Best Regards
RE: Part List (BOM) adding atribute parentheses
I just find the way after a wild, add the attribute from Annotation Style and not from Text Editor.
In the parts list style options, turn off the "highlight manual text" option.
www.nxjournaling.com
That works too!!! just another question, my part list has more that 59 items and the list split in two (even more) after item 51. I manage to reduce to 51 by changing Character Size from PartList>Cell Style, what option do I have to change to have a single part list.
Best Regards. Thanks in advance.
In the "sections" area, change the "maximum height" to a larger value (but smaller than the size of your drawing sheet).
Great, that works!!! Thanks cowski.
BestRegards
