Under Ground Water Pipes Connectors
Hi,,,
I have a problem with the water pipes couplers bolts that located under ground in corrosive soil,
what bolts is suitable in this case, and what unit-corrosion material should I use to protect them?
RE: Under Ground Water Pipes Connectors
Many people specify stainless steel bolts for these underground applications.
How is the pipe itself protected?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
The pipe is AC pipe, we use the mechanical coupler to maintenance purposes.
