Slope Stability - Crane Pad
I have an application where a crane pad is recommended on a site that has an embankment fill overlooking a tidal bay. The embankment is about 10 feet in height. For a slope stability evaluation, is anyone aware of documentation that supports a recommended minimum factor of safety against slope failure. Thank you.
RE: Slope Stability - Crane Pad
Also, for a crane pad, small movements can be a big problem.
Mike Lambert
EM 1110-2-1902 Slope Stability
Table 3-1
Minimum Required Factors of Safety: New Earth and Rock-Fill Dams
End-of-Construction (including staged construction) FS=1.3
