Program for generating XYZ & radius co-ordinate data in UG Nx
I am using UG-Nx 7.5. I work mostly on tubings & hose. I was looking for any programs which will help in creating the co-ordinate table (XYZ & bend radius) for the tubes on drawing from model.
I currenlty I have "pipebend.grx" from GM toolkit, but it has a shortcoming. In that, we have to select a line & arc in sequence or else it indicates an error. So instead of selecting line & arc, would it be possible to select intersecting points & generate the table.
Attached sceen shot of the required coordinate table.
Sundeep
Sundeep
RE: Program for generating XYZ & radius co-ordinate data in UG Nx
Have you used BEND REPORT (Routing Mechanical)? Sorry i have not used it yet myself but it looks promising in your case.One thing i am unaware of is if you have created the pipes and bends using Routing or simply created it in Modeling
Best Regards
Kapil Sharma
This is done by simple modelling. I currently donot have Routing Mechanical license.
Its just created using centreline & then sweep.
Sundeep
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
1. It is developed for NX7.5
2. It requires that the "pipe/tubing" is created using the sweep method. That is a sweep feature is created using sweep along guide.
3. Based on annotation preferences Fit methods with auto size row on, auto size text on,
auto size column on and all other options off.
Note also that the first point is not included in the points list. Not sure if this was the requirement.
CODE -->
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpenUI Imports NXOpen.Features Imports NXOpen.Utilities Imports NXOpen.Annotations Module TabNote Dim s As Session = Session.GetSession() Dim ufs As UFSession = UFSession.GetUFSession() Dim workPart As Part = s.Parts.Work Dim ui As UI = ui.GetUI() Sub Main() Dim no_pts As Integer = Nothing Dim pos1 As Integer = Nothing Dim junk3(2) As Double Dim junk2(1) As Double Dim junk1 As Double Dim theSweep As Feature = Nothing Dim response1 As Selection.Response = Selection.Response.Cancel Dim message1 As String = "Select the sweep Feature" start1: response1 = select_a_feature(message1, theSweep) If response1 = Selection.Response.Cancel Or response1 = Selection.Response.Back Then GoTo end1 Dim name1 As String = Nothing name1 = theSweep.GetFeatureName.Substring(0, 5) If name1 <> "Sweep" Then MsgBox("Selected feature is not a Sweep along Guide feature") GoTo end1 End If Dim pt1(2) As Double Dim pt2(2) As Double Dim line1 As Line Dim arc1 As Arc Dim noprofilecurves As Integer = Nothing Dim profilecurvetags(-1) As NXOpen.Tag Dim nosectioncurves As Integer = Nothing Dim sectioncurvetags(-1) As NXOpen.Tag ufs.Modl.AskSweepCurves(theSweep.Tag, nosectioncurves, sectioncurvetags, noprofilecurves, profilecurvetags) Dim obj1(noprofilecurves - 1) As NXObject Dim strpt(noprofilecurves - 1) As Point3d Dim endpt(noprofilecurves - 1) As Point3d Dim radii(noprofilecurves - 1) As Double Dim lengths(noprofilecurves - 1) As Double For i As Integer = 0 To noprofilecurves - 1 obj1(i) = NXObjectManager.Get(profilecurvetags(i)) ' get the end points, radius and length If (TypeOf obj1(i) Is Line) Then line1 = DirectCast(obj1(i), Line) strpt(i) = line1.StartPoint endpt(i) = line1.EndPoint radii(i) = 0.0 lengths(i) = line1.GetLength() ElseIf (TypeOf obj1(i) Is Arc) Then arc1 = DirectCast(obj1(i), Arc) ufs.Modl.AskCurveProps(profilecurvetags(i), 0.0, pt1, junk3, junk3, junk3, junk1, junk1) ufs.Modl.AskCurveProps(profilecurvetags(i), 1.0, pt2, junk3, junk3, junk3, junk1, junk1) strpt(i) = New Point3d(pt1(0), pt1(1), pt1(2)) endpt(i) = New Point3d(pt2(0), pt2(1), pt2(2)) radii(i) = arc1.Radius lengths(i) = arc1.GetLength() Else MsgBox("Sweep guide curve is not a line or arc") End If Next ' order the points for tabnote Dim orderedpts(noprofilecurves) As Point3d Dim l1 As Double = 0.0 l1 = Distancepoint3d(strpt(0), strpt(1)) If l1 = 0.0 Then orderedpts(0) = endpt(0) orderedpts(1) = strpt(1) orderedpts(2) = endpt(1) GoTo continue2 End If l1 = Distancepoint3d(strpt(0), endpt(1)) If l1 = 0.0 Then orderedpts(0) = endpt(0) orderedpts(1) = endpt(1) orderedpts(2) = strpt(1) GoTo continue2 End If l1 = Distancepoint3d(endpt(0), strpt(1)) If l1 = 0.0 Then orderedpts(0) = strpt(0) orderedpts(1) = strpt(1) orderedpts(2) = endpt(1) GoTo continue2 End If l1 = Distancepoint3d(endpt(0), endpt(1)) If l1 = 0.0 Then orderedpts(0) = strpt(0) orderedpts(1) = endpt(1) orderedpts(2) = strpt(1) GoTo continue2 End If continue2: For i As Integer = 2 To noprofilecurves - 2 l1 = Distancepoint3d(orderedpts(i), strpt(i + 1)) If l1 = 0.0 Then orderedpts(i + 1) = endpt(i + 1) If i = noprofilecurves - 2 Then orderedpts(i + 2) = strpt(i + 1) End If Else orderedpts(i + 1) = strpt(i + 1) If i = noprofilecurves - 2 Then orderedpts(i + 2) = endpt(i + 1) End If End If Next ' select point for tabnote Dim dwgview As View = Nothing Dim cursor As Point3d Dim response As Selection.DialogResponse = SelectScreenPos(cursor, dwgview) If response <> Selection.DialogResponse.Pick Then Return End If ' Create the tabular note Dim n_new_columns As Integer = 5 Dim tabnote As NXOpen.Tag = CreateTabnoteWithSize(0, n_new_columns, cursor) ' Get the column tags Dim columns(n_new_columns - 1) As NXOpen.Tag For ii As Integer = 0 To n_new_columns - 1 ufs.Tabnot.AskNthColumn(tabnote, ii, columns(ii)) Next Dim row As NXOpen.Tag Dim cell As NXOpen.Tag Dim cells(4) As NXOpen.Tag ' Add points Header Row Dim headerrow As NXOpen.Tag ufs.Tabnot.CreateRow(10, headerrow) ufs.Tabnot.AddRow(tabnote, headerrow, UFConstants.UF_TABNOT_APPEND) ufs.Tabnot.AskCellAtRowCol(headerrow, columns(0), cell) ufs.Tabnot.SetCellText(cell, "Point") ufs.Tabnot.AskCellAtRowCol(headerrow, columns(1), cell) ufs.Tabnot.SetCellText(cell, " X ") ufs.Tabnot.AskCellAtRowCol(headerrow, columns(2), cell) ufs.Tabnot.SetCellText(cell, " Y ") ufs.Tabnot.AskCellAtRowCol(headerrow, columns(3), cell) ufs.Tabnot.SetCellText(cell, " Z ") ufs.Tabnot.AskCellAtRowCol(headerrow, columns(4), cell) ufs.Tabnot.SetCellText(cell, "Radius") ' Add a row for each point leaving out the first point ??? For i As Integer = 1 To orderedpts.Length - 1 ufs.Tabnot.CreateRow(10, row) ufs.Tabnot.AddRow(tabnote, row, UFConstants.UF_TABNOT_APPEND) ufs.Tabnot.AskCellAtRowCol(row, columns(0), cell) ufs.Tabnot.SetCellText(cell, i.ToString()) ufs.Tabnot.AskCellAtRowCol(row, columns(1), cell) ufs.Tabnot.SetCellText(cell, FormatNumber(orderedpts(i).X, 1).ToString()) ufs.Tabnot.AskCellAtRowCol(row, columns(2), cell) ufs.Tabnot.SetCellText(cell, FormatNumber(orderedpts(i).Y, 1).ToString()) ufs.Tabnot.AskCellAtRowCol(row, columns(3), cell) ufs.Tabnot.SetCellText(cell, FormatNumber(orderedpts(i).Z, 1).ToString()) ufs.Tabnot.AskCellAtRowCol(row, columns(4), cell) ufs.Tabnot.SetCellText(cell, FormatNumber(radii(i - 1), 1).ToString()) Next ' Developed Length Dim devlength As String = "Developed Length" Dim sum1 As Double = Nothing For i As Integer = 0 To noprofilecurves - 1 sum1 = sum1 + lengths(i) Next ufs.Tabnot.CreateRow(10, row) ufs.Tabnot.AddRow(tabnote, row, UFConstants.UF_TABNOT_APPEND) For i As Integer = 0 To 4 ufs.Tabnot.AskCellAtRowCol(row, columns(i), cells(i)) Next ufs.Tabnot.MergeCells(cells(0), cells(3)) ufs.Tabnot.SetCellText(cells(0), devlength) ufs.Tabnot.SetCellText(cells(4), FormatNumber(sum1, 1).ToString()) end1: End Sub Function select_a_feature(ByRef prompt As String, ByRef sweep1 As Feature) As Selection.Response Dim featurearray(-1) As Features.Feature Dim feattype As NXOpen.Selection.SelectionFeatureType = Selection.SelectionFeatureType.Browsable Dim response1 As Selection.Response = Selection.Response.Cancel response1 = ui.GetUI.SelectionManager.SelectFeatures(prompt, feattype, featurearray) sweep1 = featurearray(0) Return response1 End Function Public Function SelectScreenPos(ByRef pos As Point3d, ByVal view As View) As Selection.DialogResponse Return (ui.SelectionManager.SelectScreenPosition("Select location for tabnote", view, pos)) End Function Public Function CreateTabnoteWithSize( _ ByVal nRows As Integer, ByVal nColumns As Integer, ByVal loc As Point3d) As NXOpen.Tag ' Create the tabular note. Based on annotation preferences Fit methods with auto size row on, auto size text on, ' auto size column on and all others off Dim secPrefs As UFTabnot.SectionPrefs ufs.Tabnot.AskDefaultSectionPrefs(secPrefs) Dim origin(2) As Double origin(0) = loc.X origin(1) = loc.Y origin(2) = loc.Z Dim tabnote As NXOpen.Tag ufs.Tabnot.Create(secPrefs, origin, tabnote) ' Delete all existing columns and rows (we create them as needed) Dim nmRows As Integer = 0 ufs.Tabnot.AskNmRows(tabnote, nmRows) For ii As Integer = 0 To nmRows - 1 Dim row As NXOpen.Tag ufs.Tabnot.AskNthRow(tabnote, 0, row) ufs.Tabnot.RemoveRow(row) ufs.Obj.DeleteObject(row) Next Dim nmColumns As Integer = 0 ufs.Tabnot.AskNmColumns(tabnote, nmColumns) For ii As Integer = 0 To nmColumns - 1 Dim column As NXOpen.Tag ufs.Tabnot.AskNthColumn(tabnote, 0, column) ufs.Tabnot.RemoveColumn(column) ufs.Obj.DeleteObject(column) Next ' Now add our columns as needed Dim columns(nColumns - 1) As NXOpen.Tag For ii As Integer = 0 To nColumns - 1 ' ufs.Tabnot.SetColumnWidth(columns(ii), 10) ufs.Tabnot.CreateColumn(40, columns(ii)) ufs.Tabnot.AddColumn(tabnote, columns(ii), UFConstants.UF_TABNOT_APPEND) Next ' Now add our rows as needed Dim rows(nRows - 1) As NXOpen.Tag For ii As Integer = 0 To nRows - 1 ufs.Tabnot.CreateRow(40, rows(ii)) ufs.Tabnot.AddRow(tabnote, rows(ii), UFConstants.UF_TABNOT_APPEND) Next Return tabnote End Function Public Function Distancepoint3d(ByVal pt1 As Point3d, ByVal pt2 As Point3d) As Double Dim l1 As Double = 0.0 If Math.Abs(pt1.X - pt2.X) < 0.01 And _ Math.Abs(pt1.Y - pt2.Y) < 0.01 And _ Math.Abs(pt1.Z - pt2.Z) < 0.01 Then l1 = 0.0 Else l1 = Math.Sqrt((pt2.X - pt1.X) * (pt2.X - pt1.X) + _ (pt2.Y - pt1.Y) * (pt2.X - pt1.Y) + _ (pt2.Z - pt1.Z) * (pt2.Z - pt1.Z)) End If Return l1 End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End ModuleRegards
Frank
But I think there are few more things to be needed.
Attached below is the example drawing for the tube.
I generated tube using sweep command & derived the coordinates using pipe-bend program & your program.
I found differences in the coordinates. The XYZ coordinates values should be for intersecting points as indicated. If you refer the isometric view, this has the required coordinates.
So can you kindly modify your program, so that I only have to pick the intersecting points (as required) and the program should prompt for entering the bend radius values in the after the points have been selected. So except the first & last point there would be radius value.
example drawing pdf file is also uploaded to :
http://www.scribd.com/doc/126172717/XYZ-Coordinate...
Thanks in advance,
Sundeep Panchal
CODE -->
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpenUI Imports NXOpen.Features Imports NXOpen.Utilities Imports NXOpen.Annotations Module TabNote Dim s As Session = Session.GetSession() Dim ufs As UFSession = UFSession.GetUFSession() Dim workPart As Part = s.Parts.Work Dim ui As UI = ui.GetUI() Sub Main() Dim no_pts As Integer = Nothing Dim pos1 As Integer = Nothing Dim junk3(2) As Double Dim junk2(1) As Double Dim junk1 As Double Dim theSweep As Feature = Nothing Dim response1 As Selection.Response = Selection.Response.Cancel Dim message1 As String = "Select the sweep Feature" start1: response1 = select_a_feature(message1, theSweep) If response1 = Selection.Response.Cancel Or response1 = Selection.Response.Back Then GoTo end1 Dim name1 As String = Nothing name1 = theSweep.GetFeatureName.Substring(0, 5) If name1 <> "Sweep" Then MsgBox("Selected feature is not a Sweep along Guide feature") GoTo end1 End If Dim pt1(2) As Double Dim pt2(2) As Double Dim line1 As Line Dim arc1 As Arc Dim noprofilecurves As Integer = Nothing Dim profilecurvetags(-1) As NXOpen.Tag Dim nosectioncurves As Integer = Nothing Dim sectioncurvetags(-1) As NXOpen.Tag ufs.Modl.AskSweepCurves(theSweep.Tag, nosectioncurves, sectioncurvetags, noprofilecurves, profilecurvetags) Dim obj1(noprofilecurves - 1) As NXObject Dim strpt(noprofilecurves - 1) As Point3d Dim endpt(noprofilecurves - 1) As Point3d Dim radii(noprofilecurves - 1) As Double Dim lengths(noprofilecurves - 1) As Double Dim angle1(noprofilecurves - 1) As Double Dim strangle As Double = Nothing Dim endangle As Double = Nothing Dim lengths2(noprofilecurves - 1) As Double For i As Integer = 0 To noprofilecurves - 1 obj1(i) = NXObjectManager.Get(profilecurvetags(i)) ' get the end points, radius and length If (TypeOf obj1(i) Is Line) Then line1 = DirectCast(obj1(i), Line) strpt(i) = line1.StartPoint endpt(i) = line1.EndPoint radii(i) = 0.0 lengths(i) = line1.GetLength() angle1(i) = 0.0 lengths2(i) = 0.0 ElseIf (TypeOf obj1(i) Is Arc) Then arc1 = DirectCast(obj1(i), Arc) ufs.Modl.AskCurveProps(profilecurvetags(i), 0.0, pt1, junk3, junk3, junk3, junk1, junk1) ufs.Modl.AskCurveProps(profilecurvetags(i), 1.0, pt2, junk3, junk3, junk3, junk1, junk1) strpt(i) = New Point3d(pt1(0), pt1(1), pt1(2)) endpt(i) = New Point3d(pt2(0), pt2(1), pt2(2)) radii(i) = arc1.Radius lengths(i) = arc1.GetLength() strangle = arc1.StartAngle endangle = arc1.EndAngle angle1(i) = (endangle - strangle) / 2.0 lengths2(i) = radii(i) * Math.Tan(angle1(i)) Else MsgBox("Sweep guide curve is not a line or arc") End If Next ' order the points for tabnote Dim orderedpts(noprofilecurves) As Point3d Dim l1 As Double = 0.0 l1 = Distancepoint3d(strpt(0), strpt(1)) If l1 = 0.0 Then orderedpts(0) = endpt(0) orderedpts(1) = strpt(1) orderedpts(2) = endpt(1) GoTo continue2 End If l1 = Distancepoint3d(strpt(0), endpt(1)) If l1 = 0.0 Then orderedpts(0) = endpt(0) orderedpts(1) = endpt(1) orderedpts(2) = strpt(1) GoTo continue2 End If l1 = Distancepoint3d(endpt(0), strpt(1)) If l1 = 0.0 Then orderedpts(0) = strpt(0) orderedpts(1) = strpt(1) orderedpts(2) = endpt(1) GoTo continue2 End If l1 = Distancepoint3d(endpt(0), endpt(1)) If l1 = 0.0 Then orderedpts(0) = strpt(0) orderedpts(1) = endpt(1) orderedpts(2) = strpt(1) GoTo continue2 End If continue2: For i As Integer = 2 To noprofilecurves - 2 l1 = Distancepoint3d(orderedpts(i), strpt(i + 1)) If l1 = 0.0 Then orderedpts(i + 1) = endpt(i + 1) If i = noprofilecurves - 2 Then orderedpts(i + 2) = strpt(i + 1) End If Else orderedpts(i + 1) = strpt(i + 1) If i = noprofilecurves - 2 Then orderedpts(i + 2) = endpt(i + 1) End If End If Next ' now determine the intersection points Dim newnopoints As Integer = noprofilecurves - 3 Dim newpoints(newnopoints - 1) As Point3d newpoints(0) = orderedpts(0) newpoints(newnopoints - 1) = orderedpts(noprofilecurves - 4) For i As Integer = 1 To newnopoints - 2 newpoints(i) = calculateIntesectionPoint(orderedpts((i - 1) * 2), orderedpts((i - 1) * 2 + 1), lengths2(i * 2 - 1)) Next ' select point for tabnote Dim dwgview As View = Nothing Dim cursor As Point3d Dim response As Selection.DialogResponse = SelectScreenPos(cursor, dwgview) If response <> Selection.DialogResponse.Pick Then Return End If ' Create the tabular note Dim n_new_columns As Integer = 5 Dim tabnote As NXOpen.Tag = CreateTabnoteWithSize(0, n_new_columns, cursor) ' Get the column tags Dim columns(n_new_columns - 1) As NXOpen.Tag For ii As Integer = 0 To n_new_columns - 1 ufs.Tabnot.AskNthColumn(tabnote, ii, columns(ii)) Next Dim row As NXOpen.Tag Dim cell As NXOpen.Tag Dim cells(4) As NXOpen.Tag ' Add points Header Row Dim headerrow As NXOpen.Tag ufs.Tabnot.CreateRow(10, headerrow) ufs.Tabnot.AddRow(tabnote, headerrow, UFConstants.UF_TABNOT_APPEND) ufs.Tabnot.AskCellAtRowCol(headerrow, columns(0), cell) ufs.Tabnot.SetCellText(cell, "Point") ufs.Tabnot.AskCellAtRowCol(headerrow, columns(1), cell) ufs.Tabnot.SetCellText(cell, " X ") ufs.Tabnot.AskCellAtRowCol(headerrow, columns(2), cell) ufs.Tabnot.SetCellText(cell, " Y ") ufs.Tabnot.AskCellAtRowCol(headerrow, columns(3), cell) ufs.Tabnot.SetCellText(cell, " Z ") ufs.Tabnot.AskCellAtRowCol(headerrow, columns(4), cell) ufs.Tabnot.SetCellText(cell, "Radius") ' Add a row for each point leaving out the first point ??? For i As Integer = 0 To newpoints.Length - 1 ufs.Tabnot.CreateRow(10, row) ufs.Tabnot.AddRow(tabnote, row, UFConstants.UF_TABNOT_APPEND) ufs.Tabnot.AskCellAtRowCol(row, columns(0), cell) ufs.Tabnot.SetCellText(cell, (i + 1).ToString()) ufs.Tabnot.AskCellAtRowCol(row, columns(1), cell) ufs.Tabnot.SetCellText(cell, FormatNumber(newpoints(i).X, 1).ToString()) ufs.Tabnot.AskCellAtRowCol(row, columns(2), cell) ufs.Tabnot.SetCellText(cell, FormatNumber(newpoints(i).Y, 1).ToString()) ufs.Tabnot.AskCellAtRowCol(row, columns(3), cell) ufs.Tabnot.SetCellText(cell, FormatNumber(newpoints(i).Z, 1).ToString()) ufs.Tabnot.AskCellAtRowCol(row, columns(4), cell) If i = 0 Then ufs.Tabnot.SetCellText(cell, FormatNumber(radii(0), 1).ToString()) ElseIf i = newpoints.Length - 1 Then ufs.Tabnot.SetCellText(cell, FormatNumber(radii(i * 2 - 2), 1).ToString()) Else ufs.Tabnot.SetCellText(cell, FormatNumber(radii(i * 2 - 1), 1).ToString()) End If Next ' Developed Length Dim devlength As String = "Developed Length" Dim sum1 As Double = Nothing For i As Integer = 0 To noprofilecurves - 1 sum1 = sum1 + lengths(i) Next ufs.Tabnot.CreateRow(10, row) ufs.Tabnot.AddRow(tabnote, row, UFConstants.UF_TABNOT_APPEND) For i As Integer = 0 To 4 ufs.Tabnot.AskCellAtRowCol(row, columns(i), cells(i)) Next ufs.Tabnot.MergeCells(cells(0), cells(3)) ufs.Tabnot.SetCellText(cells(0), devlength) ufs.Tabnot.SetCellText(cells(4), FormatNumber(sum1, 1).ToString()) end1: End Sub Function calculateIntesectionPoint(ByVal pt1 As Point3d, ByVal pt2 As Point3d, ByVal l1 As Double) As Point3d Dim v1 As Vector3d v1.X = pt2.X - pt1.X v1.Y = pt2.Y - pt1.Y v1.Z = pt2.Z - pt1.Z ' unitize Dim u1 As Vector3d Dim sub1 As Double sub1 = Math.Sqrt(v1.X * v1.X + v1.Y * v1.Y + v1.Z * v1.Z) u1.X = v1.X / sub1 u1.Y = v1.Y / sub1 u1.Z = v1.Z / sub1 Dim p3 As Point3d p3.X = pt2.X + u1.X * l1 p3.Y = pt2.Y + u1.Y * l1 p3.Z = pt2.Z + u1.Z * l1 Return p3 End Function Function select_a_feature(ByRef prompt As String, ByRef sweep1 As Feature) As Selection.Response Dim featurearray(-1) As Features.Feature Dim feattype As NXOpen.Selection.SelectionFeatureType = Selection.SelectionFeatureType.Browsable Dim response1 As Selection.Response = Selection.Response.Cancel response1 = ui.GetUI.SelectionManager.SelectFeatures(prompt, feattype, featurearray) sweep1 = featurearray(0) Return response1 End Function Public Function SelectScreenPos(ByRef pos As Point3d, ByVal view As View) As Selection.DialogResponse Return (ui.SelectionManager.SelectScreenPosition("Select location for tabnote", view, pos)) End Function Public Function CreateTabnoteWithSize( _ ByVal nRows As Integer, ByVal nColumns As Integer, ByVal loc As Point3d) As NXOpen.Tag ' Create the tabular note. Based on annotation preferences Fit methods with auto size row on, auto size text on, ' auto size column on and all others off Dim secPrefs As UFTabnot.SectionPrefs ufs.Tabnot.AskDefaultSectionPrefs(secPrefs) Dim origin(2) As Double origin(0) = loc.X origin(1) = loc.Y origin(2) = loc.Z Dim tabnote As NXOpen.Tag ufs.Tabnot.Create(secPrefs, origin, tabnote) ' Delete all existing columns and rows (we create them as needed) Dim nmRows As Integer = 0 ufs.Tabnot.AskNmRows(tabnote, nmRows) For ii As Integer = 0 To nmRows - 1 Dim row As NXOpen.Tag ufs.Tabnot.AskNthRow(tabnote, 0, row) ufs.Tabnot.RemoveRow(row) ufs.Obj.DeleteObject(row) Next Dim nmColumns As Integer = 0 ufs.Tabnot.AskNmColumns(tabnote, nmColumns) For ii As Integer = 0 To nmColumns - 1 Dim column As NXOpen.Tag ufs.Tabnot.AskNthColumn(tabnote, 0, column) ufs.Tabnot.RemoveColumn(column) ufs.Obj.DeleteObject(column) Next ' Now add our columns as needed Dim columns(nColumns - 1) As NXOpen.Tag For ii As Integer = 0 To nColumns - 1 ' ufs.Tabnot.SetColumnWidth(columns(ii), 10) ufs.Tabnot.CreateColumn(40, columns(ii)) ufs.Tabnot.AddColumn(tabnote, columns(ii), UFConstants.UF_TABNOT_APPEND) Next ' Now add our rows as needed Dim rows(nRows - 1) As NXOpen.Tag For ii As Integer = 0 To nRows - 1 ufs.Tabnot.CreateRow(40, rows(ii)) ufs.Tabnot.AddRow(tabnote, rows(ii), UFConstants.UF_TABNOT_APPEND) Next Return tabnote End Function Public Function Distancepoint3d(ByVal pt1 As Point3d, ByVal pt2 As Point3d) As Double Dim l1 As Double = 0.0 If Math.Abs(pt1.X - pt2.X) < 0.01 And _ Math.Abs(pt1.Y - pt2.Y) < 0.01 And _ Math.Abs(pt1.Z - pt2.Z) < 0.01 Then l1 = 0.0 Else l1 = Math.Sqrt((pt2.X - pt1.X) * (pt2.X - pt1.X) + _ (pt2.Y - pt1.Y) * (pt2.X - pt1.Y) + _ (pt2.Z - pt1.Z) * (pt2.Z - pt1.Z)) End If Return l1 End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End ModuleRegards
Frank Swinkels
Again Thanks, we are close.
The intersecting point chart is important as on XYZ & radius values, program is fed in to CNC tube bender & operations are carried out. Can you please look at the attached program which I have.
1.
In this program (point_chart.grx), everything is fine, except, it does not prompt for entering radius value, which is important for the product. (If needed, i can send you screen-grab how it prompts & works)
This will give you an idea so that you can modify your program or edit this program. In this pogram, its not necessary for the model to be sweep, as it derives the coordinate chart by just picking the intersecting points.
2.
I have also attached slide (just 2 pages) about prompting for picking the points, start point, radius & generates the required output on drawing (these coordinate chart is prepared in CATIA, I have similar program in place in CATIA which is in VB)
http://files.engineering.com/getfile.aspx?folder=f...
http://www.scribd.com/doc/126527811/Current-Progra...
Sundeep
The additional point ID input on the drawing can be done but I am not prepared to write the code using the point selection method you propose because it is not a good approach. Sorry.
Frank Swinkels
Sundeep Panchal
