Truncate an Attribute in a Title Block
Hi All,
I've gone through the forums with various search keywords and as well as Google searches (Eng-Tips still comes up top bigsmile) and I've learned quite a bit of very useful info from a lot of threads, but can't find a similar post.
Our company runs NX7.5.4.4 with Teamcenter 8.3.3. We're looking at automating drawing title blocks with attribute information from Teamcenter. For material finishes on Teamcenter we have a two digit code, hyphen and descriptive text, e.g. "00 - NATURAL".
The question is how do you truncate an attribute value in a title block to only show the first two digits? E.g. only show "00" in the finish of the drawing, instead of "00 - NATURAL"? Or to specify to only show specific characters from an attribute, e.g. 1 and 2; or even characters 6 to 12 if we wanted to show "NATURAL".
A particular attribute hasn't been defined yet, but I assume it will be a custom one instead of a built in one (haven't seen finish attributes yet). I've played around with a custom attribute MATERIAL_FINISH ("MATERIAL_FINISH"=(string)"00 - NATURAL"), and tried variations of <W@MATERIAL_FINISH<1,2>>, <W@MATERIAL_FINISH(1,2)>, <W@MATERIAL_FINISH,1,2>, etc. but all come up with errors.
Can it be done?
Any help would be great, thanks!
Cobus
RE: Truncate an Attribute in a Title Block
Create a string expression and set the formula to:
CODE
subString( ug_askPartAttrValue( "[your finish attribute title]" ), 2, 3 )
Now reference this expression in your title block note.
www.nxjournaling.com
Thanks Cowski! That did it!
smile
