Mechanical room live load
IBC 09. I have an existing building where they want to place a new air-handling unit on an existing elevated slab (concrete pan joists). The original use of the area was a classroom. The equipment load works out to about 60 psf (rounded up by 10) and the slab works for this load. However I have always seen new-building mech rooms designed for 125 psf min or equipment load, whichever is greater. IBC does not specify a min load for a mech room. So my question is, am I ok using the equipment load of 60 psf?
RE: Mechanical room live load
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
