Peristaltic pump
Peristaltic pump
Hi Guys
I am trying to learn about peristaltic pumps. I would like to know the effect of using more than two rollers on the flow rate? For example with a specific rotor diameter and tube parameters if you want high flow rate should you go for 2 rollers instead of three? Basically what affects the flow rate of these pumps? Sorry for my funny question but my background is in agriculture so do not know anything about the pumps.
Lilynema
Lilynema
RE: Peristaltic pump
To change flowrate you change speed.
However- as noted above- more rollers = smoother discharge flow. Generally it's speed and tube diameter that affects the flow. You'll get longer tube/roller life with a bigger tube and lower speeds.
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
