Derated Pressure answer is -tive
Attached is my claculation sheet per B31 G for corroded pipe line derated pressure, my answer is coming in -tive, can any one please check the sheet and correct me where is i'm wrong in my calcualtions.
10815L
10815L
RE: Derated Pressure answer is -tive
I have my own value of L and for pressure is psig used. i will attache it again.
thanks
10815l
I have rechecked my calculation work even though my answer is negative and uploaded revised file. can any one have experience with B 31 G check my calculation work and correct it.
Thnaks
10815L
Good luck,
Latexman
Inches is converted to meter.
10815l
