create dimensions in an isometric view through MACRO
Hi Guys,
Newbie here...
I'm trying to create dimensions of a tube part where technological features were not able to use because of followings.
1. tube has got bends. we have to show the position of the intersection of two outer lines.
- Measure the dimension accordingly.
2. Put some annotation mentioning about properties of the part / pipes / tubes.
3. doing so should not affect the visibility of the 3D Part.
Will some body let me know how can i proceed to generate / create dimensions as wells as annotations in an isometric view consisting piping's or tubing's, Spools.
or
can somebody share the same, if they do possess it.
Hoping to get a reply from someone soon.
Maddy
