How to model Vibration of Machine
Dear All,
I want to ask about the vibration of machine.
As far as I know, we need to input as sine function. Am I right?
I assumed the weight of machine is 110 kN and assumed that 10% of weight will be placed as the vibration.
I use Time History Definitions - Harmonic Function.
Sine function and frequency machine is 37.233 cps.
Amplitude, what should I input in Amplitude?
Cause I have assumed that 10% of machine weight will be used as vibration, I input Amplitude as Force 11 kN
Then cycles, I input 372 (I think its like 10 second of vibration)
Step = 0 second
Then after define Type 1 Force, I define Arrival Time
I used Time Step 0.05
Damping 0.05
0 Arrival Time
For Load Cases, I used DEAD and MACHINE
DEAD is only selfweight
MACHINE is
SELFWEIGHT X 1
SELFWEIGHT Y 1
SELFWEIGHT Z 1
TIME LOAD
77 78 117 118 FX 1 1 1.000000
JOINT LOAD
77 78 117 118 FY -110
Please your kindly advice whether my modelling is correct or not.
What should MACHINE be assigned as DEAD or LIVE load? cause it will affect the load combination
Please your help.
I have attached my Staad.
Thanks a lot.
RE: How to model Vibration of Machine
Good day.
I hope my response is not yet late.
Amplitude for machine vibration problem can be computed by:
F=mew^2
F=amplitude
m=mass of rotating element of your machine (rotor), you can have this value from vendor data
e= eccentricity (can be given or provided by vendor)
w=machine frequency
However, if some data like eccentricity are not provide by vendor:, you can rearrange above formula into:
F=m(ew)w
m=mass
ew=balance quality grade of your machine (you can search ISO 1940, if my memory is correct, and choose what grade level does your machine qualify, like G2.5 for turbine/generator as an example)
w=machine frequency
Kindly follow below steps for typical calculation:
F=m(ew)w F : amplitude (vertical), N
m : mass of machine rotor, kg
(eω) : balance quality grade (G2.5 for for turbine/generator = 2.5mm/s)
but the next critical grade/level is selected for design
(G6.3 = 6.3mm/s)
ω : machine frequency
Cheers.
