How to Remove Foam from Cooling Water Surface
Did anyone have experience with cooling water that have much foam? I have this problem for several years until now.
We have tried stopping cooling water chemical and use hydrogen peroxide only. Foam was disappears from cooling water. But hydrogen peroxide is bad for wooden-cooling tower structure. Wes stopped using it.
Please share your experiences and what the reasons of this phenomena? It will be very helpful for us.
http://chemicalengineeringmagazine.com, Free Chemical Engineering Magazine Subscription
RE: How to Remove Foam from Cooling Water Surface
Could also be pH, how high do you control your pH? What chemicals do you use in the cooling water? Any consultation with the vendors for your CW chemicals? Im sure they will be eager to recommend solutions for you.
thread378-147688: Foam In Cooling Tower
http://www.cheresources.com/invision/topic/2679-de...
Actually, I agree with you that this may happen from dead organism. But, why does hydrogen peroxide make no foaming on CW?
http://www.lenntech.com/processes/disinfection/che...
