Weldment Assembly Feature
Is there a way to create a feature (in this case a set of holes using Hole Wizard) that is done at the "assembled" level of a weldment. My example is that I've got two "legs" on one side of my design that are wide flanges and show up as one item in the cut list. I want to drill a few holes in one of the legs but keep it as a common item to the other one. I know I could create an assembly and do the hole feature there but that wouldn't work with the drawing I'm creating. These two legs are one item before the hole feature and I just need a way to combine them again even though one of them has holes in it.
Thanks in advance
Sean
Carmanah Design & Manufacturing Inc.
Vancouver, BC
www.carmanahdesign.com
RE: Weldment Assembly Feature
By default, your weldment will have a "as welded" and "as machined" configuration. Suppress your holes in the "as welded" configuration, leave them unsupressed in the "as machined" configuration. The cut-list should be using the "as welded" configuration by default.
Joe
SW Premium 2012 SP5.0
Dell T3500 Xeon W3505 2.4Ghz
6.0GB Win7 Pro x64
ATI FirePro V5800
Perfect, don't know why I didn't think of that. Too much work lately.
THanks
Sean
Vancouver, BC
