Different material properties, but same result
Hello everyone,
I am doing a very simple model, a center fixed disk subjected to a concentrated edge load. However, I found out that even I change the material properties, the results will be the same. So I am really confused about this. Do you have any idea about how this happens? Thank you very much!
RE: Different material properties, but same result
