Vibration of pumps
Vibration of pumps
Dear Friends,
I'm not a Equipment man. But I'm piping stress analysis.
I have a question:
Have you ever seen vibration of pumps? what is the reason of this vibration? have you ever seen use of expansion joint at suction or discharge of the pump for damping this vibration?
I have a question:
RE: Vibration of pumps
Unless it is a natural frequency problem, that wouldn't help.
P.S. thank you for saying "damping" and not "dampening." Getting the vibrations wet would not help.
Pump should have a concrete foundation which is 2-3 times the mass of the pump. If not, there may an increase in vibrations.
A pump that is operated off the best efficiency point will exhibit more vibrations.
Johnny Pellin
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
Long ago I was asked to look at a 4000 HP pump that had a working pressure of around at 240 psi. I can't remember the capacity of the pump but I beleive the pressure thrust was around 120,000 lbs. Then engineer had a restrained victaulic coupling between the check valve and the butterfly valve. The play in the restrained coupling allowed the pump went for a walk when the pump was started up the first time. I advised the Owner that tie rods should be installed between the butterfly valve and the check valve to make the joint rigid (same as a flanged joint). It worked. The engineer did not know the subtilties between a restrained joint and a flanged joint.
The same engineering company did the same thing on a 72" diameter line in a water plant. The pressure thrust was around 700,000 lbs. The restrained couplings engaged under pressure as it should. The movement however cracked the shoulder on the concrete pipe supports. All of the couplings were removed and replaced by welded joints. I advised the Owner well before the piping was installed that this would havppen. There have been a lot of catrostrophic coupling failures in the US. The engineer shoould have just specified welded joints.
Pump vibration can be caused by a lot of things. Most were mentioned above. The other thing that can cause vibration is if vortexes or air is being sucked into the pump suction
